a lawyer, an electrician and a bank manager were swept overboard into shark infested waters. the sharks came and ate the electrician, bot left the other 2 alone. WHY?
You have just walked into a dark two-storey house. There are three light switches on the first floor A, B and C. Only one of the switches works, and it turns on the light on the second floor.
You cannot see the second floor light from the first floor and there are no windows in the building, but you do have a torch.
You can only make one trip up the stairs, and you can only flip one switch at a time. How do you determine which of the three switches turns on the light on the second floor ?
If a peacock lays a egg on the pinnacle of mount everest facing south and there is a prevailing north westerly wind which way would the egg role ?
Choose a switch and leave it on for 5 mins until it gets hot. Then turn it off. Then a second switch on for say 20 secs and turn it off. Then switch 3.
Run upstairs.
If bulb is on then its switch 3
if bulb is warm then switch 2
IF hot switch is 1
Or use a fuse finder kit ... doh
What happens when an irresistible force hits an immovable object?
This paradox arises because it rests on two premises:
1 that there exists such things as irresistible forces and
2 that there exists such things as immovable objects
Both cannot be true at once
The tape was rewound.
I thought I'd bring abit of harmless fun to the site.....
Heres a riddle but no cheating!!!!
'A man was found dead in his study. He was slumped over his desk and a gun was in his hand. There was a cassette recorder on his desk. When the police entered the room and pressed the play button on the tape recorder they heard: "I can't go on. I have nothing to live for." Then there was the sound of a gunshot. How did the detective immediately know that the man had been murdered and it wasn't a suicide?'
