have to be a bloody big hole to lose half the weight of the barrel.
you are at work, driving your bus.
there are 12 passengers on board. at the first stop, 3 get off and 4 get on. at the 2nd stop, 5 get off and 2 get on. 3rd stop, 7 get off and 0 get on. last stop is the terminus. all passengeres disembark.
what was the bus driver's date of birth.
I was rather assuming it was full of beer :D... mind you at 10KG that's not much beer :(. I started by trying to think of ways to displace the fluid by adding all sorts of stuff to it, that was harder than most.:mad:
correct. i can see i'm going to have to be more devious.
why would andre previn be at high risk if working on "live" electrics?
hay didle didle the cat did a piddle all over the kitchen floor the little dog laughed to see such fun so the cat did a little bit more
Two bodies found dead in a room. The room is locked from the outside. There is some broken glass on the floor and the carpet is wet. How did they die?
from drinking water. i know it would kill me.
Cat??? no. the cat would have ate them.
high pitched noise, e.g. kylie manure on the radio, shattered the goldfish bowl?
Like the last analogy, and very close, the bowl was shattered but how. Think a bit more about the glass on the floor ;)
