I don't really know why, but I enjoyed this post / thread ... so thanks Durham.
I must be easily amused!!!!!
2mm drill 2 shallow holes, 1 each side, then remove with one of thosesecurity screwdriver bits with the middle bit cut out. one removed, make slot with hacksaw.
must have been overtight, or........ was a neon driver used to break it?
Durham, I have a full set of neon screwdrivers.
I get good test results off mine, rarely get any faults on my installations.
I will post you one of mine that I used for my 2391...............
you get a much better resault if you stick your tounge on the end instead of your thumb
and for those who think i was seriouse i was joking some numpty will do it ..that will be a one for u tube
it will probably also land you in court under a claim on your professional indemnity ins..!
DurhamSparky,
DurhamSparky,
