K
Knobhead
Yet another visit the doctors yesterday. On top of all the painkillers, she now wants me to go for an ultra sound and blood tests for prostate cancer. She wants an answer if I want the tests done when I next see her. I know I’ve no option other than to go. Apparently the tests aren’t very conclusive the first time so more could follow.
Anyone else had this done?
The Ultrasound is quite simple.
You lay on your back, the squidge some gel onto your abdomen and rub the sensor around.
It'll show that your prostate is enlarged because like your ears, it doesn't stop growing.
If it's very large, then that might be an indication of cancer. The person doing the test will be able to tell you then and there if it's overly large.
The blood test will be more likely to show anything, they'll check what's floating around in your blood and if somethings are too high, that might also be an indication.
You'll probably have to go without food from sometime the night before the blood test. Takes up to a couple of weeks for the results to come back.
If there are any indicators, they'll probably want to do a biopsy.
Early days yet.
If you do have to go for a biopsy, it's a fairly quick proceedure, should be in and out in a day.
Can be under local anesthetic, or general.
If you can go private, I'd suggest you do, much nicer hospitals, and you may find that you go there the morning of the proceedure and are out in the evening.
With the NHS, it's likely that you will have to be there the night before.
Can cause some discomfort for a few days, there may be some bleeding for a while, but you are probably used to that I imagine.
Best not to ride a motorbike to the hospital.
If you're on antinflamatories, such as Ibruprofen, you'll probably have to stop taking them a couple of days before the proceedure.
echo above : best of luck, mate. hope it all turns out well.
I’ve got a fortnight before I say yes or no. It’s got to be yes. But I’m dreading it!
Thanks for the support, I may need it later.
Nowt to worry about mate, just procedure. My old man has just had the same thing after going to see the doc regarding having his pinky finger stiched back on after a HORSE bit it clean off........I **** you not!!!
He's 57 I think.
I had testicular cancer 14 years ago.
All I can say is have the test done and do as the doctors tell you, I am still here and I have had 3 more kids since cancer.
He's 57 I think.
LMFAO!!!
Dude, they should make a film about your life, and the people around you!! Insanity must run in the family.
There are so many questions that arise from you post.
1, How the hell do you go about getting a finger bitten off by a horse?
2, what was the finger doing in dobbins gob?
3, how did your father go about retrieving said didget from dobbin?
lol only in lennys life!
Glad your dad was ok after the incident tho mate!
mate I hope it goes all goes well. Dont stress until you get the results and have a definite answer. Take it day by day and Good Luck.
What sypmtoms do you have? and what are you taking painkillers for? If you dont mind me asking...
