N
nickblake
Yet again another old lady ripped off by a poor job , no certs issued , i got the call today that she had a live wire in the kitchen ,so get there yes a wire was exposed but the fuse had been taken out this was supplying an old window fan and she had had the window replace so to move the old one it was cut off , so fair enough , then looking at her other problems she described a box keeps tripping out ,small one way consumer unit feeding new sockets in her kitchen main switch RCD 32 amp breaker supplying the kitchen ring , fine nothing wrong with that i hear you say ,well heres the crunch the consumer unit was tapped off a radial socket in the garage which is then supplied from a BS1361 30 amp fuse nice one so new kitchen new tiles all behind the cooker down to the floor , and directly above the cooker is the old cooker switch which was early 80's and in very poor condition ,i ask my self in disbelief why was this not moved when the kitchen was done and to add to it there have been 2 twin sockets tapped off that as well as the cooker , the consumer unit is an old 3036 coverted to 1361 fuses and 3871 MCB's with one of the MCB's in poor condition this is located in an alcove about 8 ft from the floor above a central heating boiler how the hell is the 92 year old ment to reach that if the MCB trips , no bonding to the oil service which is directly below the consumer unit nor any bonding to water which is in the same place ,the sockets have been replaced with the cheapest sockets in the history of electric ,and make it even worse they have been tiled round and grouted in so with out wrecking the tiles are almost imposible to remove , they guy that did it needs bringing to justice ,with just a little thought , it was one of the easiest kitchen referbs in the history of man kind lower and reloctae the consumer unit , move the cooker switch add an extra socket simple the whole job should have taken less than 2 days , this has annoyed me so much that its going further ,the old lady 's not going to do anything but i most certainally am ,Where has the passion in our buisness gone where is the though , how an old lady will access her consumer unit how
a very angry nick !!!!!
