Depends a bit on how helpful your LABC are. Mine were happy to inspect after I had changed the CU urgently when we moved in (lots of probs on old installation), and then re-inspect after I had done a complete re-wire and tested/self-certified, all on the one notification and payment. Same again for loft conversion electrics later. Am not on any competent persons scheme (but am a Chartered Electrical Engineer).
You might have more trouble if you have started the work already!
And there, .....IS the very big difference!! lol!!! No-one's going to argue with you on your installation are they, ....not unless of course you made a ''Blatant'' mistake somewhere!!
Could be very much different, if you were say an industrial electrician rewiring his home
and not too sure of some of the finer points of domestic wiring...lol!!
Possibly :D.... but I suspect, that the LABCs and the part P authorizing bodies would be far happier that all electricians went down the self-certification route, for all sorts of reasons.
Well the LABC's also have the means to provide that facility, by putting those electricians that are suitably qualified, on there ''Approved'' register. By not doing this, seems to be based on monetary income, than anything else. ...Unless i'm missing something here?? lol
DRDAVIDBANNER,
Engineer54,
