i need a light to illuminate a farm yard, i will be mounted on a shed approx 10M up, and needs to illuminate approx 300M² of yard.
there was a sodium lamp there, but it was poor quality, the plastic went brittle over 2 years and cracked where it mounts(probably from catcing the wind) and then let water in, which subsequently kept blowing the MCB.
so i am looking for an energy efficient one, with a photocell, that is tough and durable and preferably IP 66 minimum. whats the best thing on the market that meets my criteria?
thanks in advance
Exarmy Ring ya wholesalers and speak to the (one sometimes 2 or 3) who has a brain :D
Im lucky iv got 2 at my Wholesalers, I tell them what im after and the price range and bingo :D
metal halide. 400watt. you may need 2 for that area.
Steinel XLed FE25 (around £300 full trade, but avail cheaper).
Scrap that it's only IP44
LEDs for 300sq.m........ be pushed to illuminate 300 sq. in.
Put 2 cheap floodys up and make sure is loader/tractor cant reach that high.. He ll be happy and you ll get to change bulbs for the forseable...
A 80W LED flood is as bright as 800W Halogen and about 50000 hours life on the LED.
I fitted one the other day and was impressed.
really I've been doing comparisons today albeit 58W tubes to LED they come up slightly brighter but not to a ratio as you've put
Spec gives the steinel (60W) as:
Voltage - 230v - 240v, 50 Hz
Energy Consumed: 60w
Light output approx: 300w Halogen
Life of LEDs: - up to 50,000 hours
was going to ring the wholesalers, just wanted to know what i was talking about before I do.
last time i asked the guy at the wholesalersfor advice i got sold the wrong parts and was told a load of crap!
ExArmy,
a1guvner,
