I think also a clue is in the callout. Was the fan working at some point as this would rule out problems with miss-wired switches.
Gentlemen, if we have guys using different coloured cores for lives and switch lives and even neutrals how can we be expected to understand WTF someone has done. Niceic printed cable colours along with many other publications. Old colours were RYB - live/switch live/neutral and new colours BR/BL/Gry so brown = Live: Black = switch Live (sleeved brown) : Grey = Neutral ( sleeved blue) Simples!
That's all well and good if you're signed up with NIC, but wouldn't it be better if the use of specific coloured cores in various typical situations was explicitly recommended in BS7671 or even the On Site Guide (I'm sure someone will correct me if it is). Although, of course, you use sleeving I really think that they missed a trick when amending the regs.
They should have made them all grey or whatever, preferably a colour not in the old scheme so you knew they were new, and you have to sleeve them with a uniquie colour that identifies them as specifically L1,2,3, switched live, N, etc. That way, there is no confusion. All you have to do them is worry about who sleeved them, but a quick check would verify what they purported to be. Which we all do anyway.
And if they were not sleeved, it would force you to check them and not trust what they purported to be too.
Having colours that can be used for various uses, is just loose regulation, especially when they went to all the trouble of changing.
need colour id....otherwise you`d spend more time bellin em..lol....
In all honesty it doesn't get much simpler than a bathroom fan with an over run.
Just step back, have a brew then look at it again. I'm sure it'll all become clear
DirtyDog368,
Amp David,
