K
K-Lye
Hi all.. I'm not an electrician by profession but not above doing any basic work that doesn't need qualification. I've got a scenario currently where I'm installing a new light switch - it's an fully enclosed unit with the terminations on the rear which leave part of the wires exposed where they terminate. Once mounted, this will be within the wall cavity of the stud wall where it's being installed. Not a real problem in itself but I prefer things to be done as best as possible so looking to dab so electrical sealant on the exposed wires (once fully terminated) to ensure they're fully insulated.
So here's the question - I know you can buy specialist electrical sealant but I believe that's industrial grade stuff and a bit overkill for the standard domestic 240V. I spoke with the local electrical specialist down at our B&Q who said normal silicon sealant would do the trick. That seems consistent with advice I've read online but I wanted to post here and get some expert views.
Thanks!
Thanks!
