HappyHippyDad
Supporter
Hello,
After looking around lots I have decided on Alphatek (Metrel) Easiplus MI3000
I have reviewed this tester and like it. My only concern is that the seller is saying that it is an older version and has said it is '16th ed' (see pic above, this is the actuall one for sale).
I am new to electrics and will not be finishing my course for sometime but wish to buy a MFT that I can sign off work with. Once I get this one calibrated could I use this one to do that? Its just his use of the word '16th ed' that worries me.
Many thanks,
Happyhippydad..
worry not. as long as it performs all the tests. i'm not familiar with the model. i would check to see if it will preform auto RCD and ramp tests.
edit: just had a brief look at the spec. on test-meter ( forum sponsor) seems it does all the tests. £335 + VAT, brand new from them.
It depends what you are trying to do if you are starting up on your own then fine buy a tester but if you are working for a company dont buy one
So once you decide to get on then yep do your homework get feedback see what your budget is now I could say buy a Fluke or a Megger but to be honest in my view Fluke have been trading on their name and Megger have had "teething" problems with their new 1700 series. Me I opted for the Megger 1553 I like it but the secrt to having a good tester is to look after it ie its not there to hammer nails into a wall with.
​so that's why mine's dented.
Thanks for that telectrix. Could you tell me where to view this one for £335, I cant find it on the metrel site or on this site?
Thanks..
If you are in no hurry keep an eye out on Ebay for a good second hand tester. I picked up a Fluke 1653 for £400 which had been used twice and still had the plastic on the scene. My advice would be go with what you are familiar with especially if you've got no one around to show you the ropes.
Yep I got my PAT tester at test-meters it was a bundle offer and I got a good deal but I bought my Megger 1553 at ISSWWW because of cost
I have now bought this tester for £225 on ebay from a retired policman! With my limited ability at testing (restricted to continuity/IR/polarity) it seems to work fine, looks as new and comes with all accessories and carry case so I'm very happy.
The £335 you mentioned telectrix was without VAT at 20% or £10 delivery so I thought the almost £200 saving worth it, although I will have to get it calibrated!
The only very minor down side is that its been on charge for 20 hours and only seems to get to 50% battery charge as the chap hadn't used it for around a year. I'm assuming its just normal rechargeable batteries rather than anything fancy?
Thanks again for all the advice..
Happyhippydad :-)
i got mine of ebay....just come back from the callibration house....and it sailed through.....but this isn`t always the case......ebay=lottery.....might not pass callibration...might be pinched.....if you do decide on the second hand/ebay route though....treat it to some new test leads as the callibration house will use the test leads that come with the instrument in order to callibrate it....and its often the case that an otherwise perfectly good tester has failed callibration....because of the leads.....
I am a little late to this thread mate but make sure you look after the leads. They are very prone to becoming useless. We had a stock of 8 of these for learners and we are down to two. All the tips fell off and the clunky lead port seems to offer variable resistance levels. It is likely most of these factors result from guys not respecting equipment that doesn't belong to them, but just treat yours gently.
As for the rechargeable battery, all of ours need to be recharged before each days use, can be annoying.
Otherwise, when its all working and charged it is a good piece of kit.
absolutely widd.....and it will usually be low ohms where problems manefest themselves as regards leads.....
Its a nifty little tester that does a few things, like Phase rotation. Test Meter may have been worth the extra (you get 5% forum discount) and when I got mine from there I got a multimeter and a breakout box free with it to. When you add in that you need yours calibrated and that you won't have the 3 year guarantee or the free goodies, the savings seem like a bit of a gamble, quite a lot of nicked stuff ends up on Ebay.
The tester can also test time delayed RCD's (not sure how general a function this is with MFT's?)
Happyhippydad :-)
If I remember correctly the battery pack is AA rechargable cells, I haven't looked in the back of mine too often but pretty sure this is the case rather than it being something better. That long a charge is a little worrying, from nearly dead to full charge I get overnight on my unit which is about 2 years old now.
HappyHippyDad,
GLENNSPARK,
