went ok. They asked a set format of questions that went along the usual lines, are you a leader or follower? what do you know about the company? Where do you want to be in 3 years? Are you willing to use your own car? and explain some testing stuff like how do you calculate cables sizes? What is the formula for Zs? Explain the importance of it? Explain how to test a ring final.
will find out monday.
cheers.
cheers.
I hate those first 3 questions.
Technical stuff, stroll in the park! :-)
Forget about it till Monday.
I couldn't quite remember the whole procedure for deciding on which cable/device to use, but explained about calculating load demand in amps from the power divided by the voltage, then choose a device rated nearest to that. Shamefully i folded a bit then and said I couldn't quite recall but it's in my book, then the conversation turned to voltage drop and he seemed happy that i knew the equation for that.
best o luck voltz......as archy.....tech stuff...i reckon you dont have anything here to worry about.....its just the other stuff.....like `are you a leader or follower`.....i suppose it depends on the type of job you have applied for really....wether you have to think on your feet or wether its `just do as i say not as you think`.....i think the fact that they were asking you if you were willing to use your own car might be a clue......as in you may be expected to go see to stuff on your own.......so that would be thinking on your feet as situations manefest themselves on site...wouldnt it.....and that demonstrates tendencies towards leadership........
Back in the late 80s, I had an interview with Ferranttis for a Software Engineer.
After having an argument with the interviewer over something techy, he leaves, a few minutes later some lass comes in and says 'I'm to show you off the premises'
So yours won't have been that bad!
For the record, HE was wrong! :-)
i just said i'm bit of both, happy to follow under good leadership, but not backwards in coming forwards either. Somehow that got twisted around to him saying he wasn't happy about people griping under poor leadership, that people needed to be helped to be good leaders, grrrrrrr 'I wasn't saying that!
Don't you just hate when you think you giving a considered, balanced answer then you get made out to be a troublemaker?
Not a good point in the interview.
oh yeah, what voltage do you test 400v circuits for IR at? I said 500v. He said no, 1000v.
Local college taught this wrong for years until I pointed it out in the Regs!
SO, you were right.
I'll be in touch in a bit.
SO, you were right.
yes and i keep seeing 2 MEG as the minimum resistance value n all in here......ok granted if IR testing is conducted globally then yes 2MEG.....but you dont fail it do you......test each individual circuit....and its a minimum of 1 MEG.......
so what premises was this lass that came in showing you then Archy??....
yes i was asked about this as well. Got that bit right too, and referenced the old values!
