H
highspark
How do you guys pull your cables through conduit. What have you found the best method.
well i was using a pump action spring which was great for long runs and bends, which the nylon one was useless . pull in draw wire and walla.. easiest way so far for me
I've seen that nylon stuff. I can only find it in 30m runs though. With that are you just essentially pushing that through one end to the other and then tiein on at top end? There all kinds of methods on the web....light string and hoovers etc. I've always found pulling to be a nightmare of a job!
i find them nylon ones arnt great if few bends and longer runs..
theres a spring one which is great, costly tho, and dont be tempted to pull the cable with the spring.....
Plenty of tallow ........................ a lot of swearing ............................ and get the box lid back on quick
I always use to marveled at how much lovely different coloured PVC swarth came out of the conduit while you were pulling in new cables, especially if the conduit was on the cosy side ...............
i always run a bit of cutting paste over the cables, makes it slide round those tight bends..
I was always told that things like liquid soap and washing up liquid can degrade pvc over time. Don't know how true that is though.
A few thing that make life much easier are;
  • Design your circuits so that the conduit is sized to be <50% full with all the wires in.
  • Use manufactured bends or hand make your bends in 3 or 4 stages over a good radius.
  • Make sure there's no more than 2 bends per conduit run.
  • Pull slow and steady in general and especially if things become tight.
  • Avoid cable twists and criss crossed wires.
highspark,
Engineer54,
