hi jason,
just looked through part m and its probably me but i cant find the part where it says cu HAS to be between 450 and 1200 :o any chance of a pointer please :confused:
"The Building Regulations require switches & socket-outlets in dwellings to be installed so that all persons including those whose reach is limited can easily reach them.
A way of satisfying the requirement is to install switches, socket-outlets & controls throughout the dwelling in accessible positions & at a height of between 450mm & 1200mm from the finished floor level.
Because of the sensitivity of circuit breakers, RCDs or RCBOs fitted to consumer units should be readily accessible"
About as unambigious as usual then? :confused:
I`d personally read that as switches, s/o`s & similiar switchgear at recommended heights (& it does look like a recommendation don`t it) but CUs at readily accessible position.
But i`m sure some BC`s could/would read it another way (& some moderators too:D)
im with you electricAl, common sense is the order of the day ;)
I think someone mentioned it but outside lights need to be 150W max with somesort of lighting control such as PIR. Last time I looked it was 25% energy efficient (Which means equal to OR better than 40 Lumens per circuit watt) but heard rumours of increase to the 33% to come into force.
Becareful of the Regs working against each other, loft spaces require 'un-broken' insulation which causes a bugger with downlights which require 'free air' to breath. Although many manufacturers make insulation guards such as Aurora - 'Passionate about Lighting' but they are not cheap and add to the overall cost.
mags1972,
Bright Sparks,
