C
craig1000
Hey everyone,
Came across a unusual type of cable today that i have never seen or heard of before & wondered if any light could be shed for me?
Its a mains feed from a meter position in a block of flats & on first glance looks like a 6 or 10 mm 3 core swa but is actually a outer sheaf & no armour with a single core line conductor (red) i would estimate 16mm & then 7 single core neutral conductors (black) i would estimate 1 or 1.5 mm & also 4 strands of uninsulated CPC!
Split concentric cable. Very common for lateral mains from ryefield board to cut outs in flats.
Feed from meter but to what ? i must say ive seen anything like this did you get a picy ?
Cheers guys, im sure its not unusual if you have come across it a few times, myself however for the first time, ten years in the game & was like 'HHHHMMM hello then whats this beauty? ' ;-)
I shall also research it now but can you tell ,me its advantages or why it would have been used?
:75:i've never seen the loch ness monster, but that doesn't mean it does not exist.
it must exist because it has relatives. i know, i was married to one of them.
never thought of cable, otherwise i could have scrapped her instead of binning the *****
Use it all the time for sub mains and is so much easier than SWA.
Only where RCD protection is not required though.
