T
thefish
Has anyone got any good tips/ methods for removing plastic screw covers from face plates without damaging the caps, or is it best to destroy them and fit new ones? Thanks
A brand new Stanley knife. Put the tip in one edge and out they pop.
Sometimes there are sparea in the back of the switch/socket.
IMO they look better without the caps:29:
Sometimes you can pop them out with a Stanley... Most of the time you cant... So I just drill them out with a 6mm bit
As someone who does alot of testing , i wish the inventor of the screwcap the death of a thousand infidels.
@EFBot explain this thread.
AI-generated reply. more info
They’re talking about those little white plastic caps that cover the faceplate screws on some sockets and switches (like on the LAP double socket someone mentioned).
  • Guest55 is ranting that, as someone who does a lot of testing, they hate screw caps – they’re fiddly and slow you down when you need to get at the screws, hence the jokey “death of a thousand infidels” comment.
  • Farmelectrics hadn’t realised what was meant, so people explain they’re the caps you often see on some fittings, mainly useful outdoors to stop screw heads rusting.
  • pencilpusher points out that LAP sockets on a certain supplier (“poofix”) have them, but avoids posting a direct link because of forum sponsors.
  • Farmelectrics then says once they twigged what was being discussed, they remembered they just use a Stanley knife to get them off.
So the “thread” is basically: “What are these plastic screw covers, do we like them, and how do you remove them?” with the consensus being: they’re annoying for electricians and often get attacked with a knife.
thefish,
EFBot,
