Only thing I didn't like was socket's labelled north and south, not seen it done before but could make things potentially confusing for someone with no sense of where north is (ME!!!)
And in regards to meter tail's, what's the problem with keeping both inner and outer sheath the same length? I have always done it like that, I wrap a bit of blue or brown tape around the live or neutral
Yes, we had some discussion about the labelling. Problem is that you'd never get a complete description of the points served on a small label (eg, "kitchen, plus two sockets out of three in dining room, plus one in hallway, plus two out of three in main bedroom"). Using left and right, you'd have to say whether looking AT front of house or looking OUT of front of house, so not definitive either. It was the best we could come up with. We're going to add a floorplan with the points marked with circuit numbers.
Unless it needs to stay on (exposed cable), I always cut back the outer sheath of tails to reveal the insulation colour. Although not likely in the short term, tape can eventually get old and fall off. Ideally I'd use tails with brown or blue sheathing, like the meter fitter has used.
