La Poste
Brake fluid gets into the inlet manifold via the vacuum pipe that leads from the vacuum drum/brake servo , the big round thing underneath the brake master cylinder.
I can see the logic with this, on my old Peugeot 306 DTurbo the vacuum caused by air being pulled into the inlet manifold is used to suck air out of the brake vacuum drum/servo. If the master cylinder is leaking then brake fluid will leak into this vacuum drum/servo, this fluid will be pulled through the pipe that connects the vacuum drum/servo to the inlet manifold and the fluid will then enter the diesel combustion chamber and be burnt along with the diesel fuel, it is quite possible for this to happen is you have a brake servo connected by a pipe to your inlet manifold.
My Peugeot has an EGR valve but I took it off as it is unreliable, I cannot see how a faulty EGR would produce white smoke, it might do if the engine is cold but not if the engine is warm, well in my opinion anyway a faulty EGR would not produce white smoke if the engine is warmed up and operating at normal temperature.
The vacuum pump that creates the vacuum for the brake servo, is it connected to the inlet manifold or is it a standalone pump that has no physical connection to the inlet manifold?
Solving problems with cars or vans is like solving electrical problems, you need the right test equipment otherwise it's guess work.
