S
Strima
Pixies and fairies... Do you know nothing? :lol:Also, someone please tell me how brake fluid can get into the inlet manifold on a Diesel engine
Maybe someone poured the brake fluid in the wrong hole?Pixies and fairies... Do you know nothing? :lol:
Lol meant to say lambda , tried to correct it but b/band dropped out :shame::shame::shame:Lambda sensor
if a Turbo went it would be black smoke as the Turbo is lubricated itself by the engine oil
Brake fluid gets into the inlet manifold via the vacuum pipe that leads from the vacuum drum/brake servo , the big round thing underneath the brake master cylinder.
I can see the logic with this, on my old Peugeot 306 DTurbo the vacuum caused by air being pulled into the inlet manifold is used to suck air out of the brake vacuum drum/servo.
The vacuum pump that creates the vacuum for the brake servo, is it connected to the inlet manifold or is it a standalone pump that has no physical connection to the inlet manifold?
I was being sarcastic when I wrote this but then I remembered years ago working on a mk4 escort, it was a rs turbo, there was a small pipe coming out of the washer bottle, through a actuator and into the induction (before turbo) looked into it, was a boy racer bolt on, the idea was that injecting a fine mist of water into the induction makes the air denser, allowing more fuel to be burnt, would have liked to see it if they got it wrong - bent rods!Maybe it's washer fluid?
Unless it's a six stroke engine...I was being sarcastic when I wrote this but then I remembered years ago working on a mk4 escort, it was a rs turbo, there was a small pipe coming out of the washer bottle, through a actuator and into the induction (before turbo) looked into it, was a boy racer bolt on, the idea was that injecting a fine mist of water into the induction makes the air denser, allowing more fuel to be burnt, would have liked to see it if they got it wrong - bent rods!
Personally a thought the whole thing was a load of rubbish.
So that rules out brake fluid then, it must be water or unburnt fuel.
Thank you amp David, some one that agrees,As per a post on the 1st page of the thread. We'll get there in the end lol
