If you have an electrician working for you as part of a building project why don't you ask him? Surely he would be best placed to answer your questions as he is on site and can look at the legacy installation.
Stu
Stu
Answer = cus he hasn't
I will do Stu. Just like to get ahead of the game and know what I should be looking for. Have accepted professionals advice before and been burned so I always try and ask questions before simply accepting what I'm told. Thanks for the responses all the same.
So my question to the experts is what do you think I should get?
The blunt answer is you should get a competent electrician in to do the work.
Your main board is stickered as being fitted in July 2012 is that right? If it is right, then it's potentially wrong - the board that is. The way its been fitted.
Can't comment on whether your 6mm SWA is correct as that will depend upon a number of variables - installation method, voltage drop etc etc.
As for CU's in the extension, if there are 2 FRC and 2 lighting circuits that adds up to 4 circuits, so you need at least a 4 way board, or maybe 6 to allow for any future expansion. Personally I don't like Wylex. I lost faith in their products with the MCB product recall and having had recent contact with them, like them less now. I'd buy a Hager board myself, but that's personal preference.
I see your location shows as the UK. There must be thousands of competent electricians in the UK that could assist you?
It was fitted way before I got the house. And I had an electrician come in and fit a 6mm cable for a duel fuel cooker. He tested and inspected it then.
As I said before I will be getting a competent electrician to do the job, and now will ask him to buy everything himself. Just wanted to make sure for myself by asking qualified pros such as yourself, the correct method of doing it.
ie. terminating the 3 core SWA cable in the main CU, and then running it to a smaller CU that has an RCD as its main switch and then two 16a MCB for the 2 socket-outlet circuits and one 6a MCB for the lighting circuit.
he should never have left the thing without blanks really and something doesn't smell right either unfortunately, he asked you to get a board?
Well it's a fairly large project and we're running around doing things at a 100 mph, so I suggested I can get stuff if he tells me what to get to save time.
Hilarious. What is all this smelly talk. Typical forum, everyone gangs up to call the OP a liar. It's my place. I'm getting some work done to the house, part of it is running electricity to the back. Let me guess? That smells fishy.
As you are employing the services of a professional electrician to carry out this work he should be telling what to buy it will be his responsibility to design the install, ask him..that's what he is being paid to do,he shouldn't be too busy to have a conversation with his customer..if I was a cynic I would suggest this is a DIY job..but of course I'm not ;)
J
Tell the builder/electrician/bloke from the pub to source the parts himself. He knows what he needs and can get a trade price saving you money. You're paying him to do a job.
Worst case scenario 6 seperate circuits, I would buy a whylex 8 way board with rcd, handful of blanks and put it on mcb at house end not on rcd. And give your electrician a kick up the bum!
Thanks fellas. All your advice is much appreciated.
And you guys are right, I'm paying him to do a job. Get it done right.
