Driving a new rod into an existing hole created by an older rod.
I'm no TT expert, but reckon this may nit give you the best results compared to driving a new rod/s into fresh ground. That is unless the new rod is much thiker and longer than the old.
Is it not possible to cut out a square section of the concrete to fit a decent earth rod pit? Looks a lot neater and more professional in the end.
If you put a earth rod box on top of path then that could be a trip hazard for the home owner if they come out in the night and cant see it .
