Discuss Bathroom extractor fans in the UK Electrical Forum area at ElectriciansForums.net
As pointed out above the 3 pole thing was to cover rooms with no windows and the resulting issue of maintenance with no lights....
Therefore....
Common sense tells me you don't need (oh! Contentious!) a 3 pole fan isolator for every fan!
Discuss
Isolators, Isolators everywhere :)
I prefer a local isolator for each fan (that way i get to turn it off when i dont want it to work ie loo breaks hehehe)
Seriously i do use a isolator for every fan i install regardless of light in rooms but i install humidi fans to bath rooms and only timer fans to wc,s with no windows (and as a norm i find most clients turn the isolators off anyway :( )
Ps and that would be the same effect as switching off the single pole FCU i think you could reasonably fit in many cases (unless manufacturers instructions say otherwise)
Reply to Bathroom extractor fans in the UK Electrical Forum area at ElectriciansForums.net
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
Evening all, Got a vent axia TX6 6” fan I need to replace. A like for like replacement is around £500, client is asking for a cheaper option...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Just had the following extractor fan fitted for my bathroom, recommended by my electrician. Based on the manual it states the fan should be...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
