Currently reading:
Bathroom extractor fans
Discuss Bathroom extractor fans in the UK Electrical Forum area at ElectriciansForums.net
B
Bridgemegger
OK, I’m sort of qualified – time served on the 14[SUP]th[/SUP] edition, then left the trade in 1973 – kept my hand in for a few years….. I’ve recently moved into a house which has a lash up of an electrical installation, and I’m tackling one thing at a time. I’m armed with a copy of the 16[SUP]th[/SUP] edition of the regs and Brian Scaddens guide to 17[SUP]th[/SUP] edition. I have a megger (albeit 500v), Earth Loop Impedance tester and RCD tester (not that I’ve got an RCD to test yet!) It’s a bit of a nostalgia trip actually, as the house was wired in the mid 60s, when I was in the trade - brown Crabtree toggle switches, buckle clips, etc. The original installation is good (but dated), it’s the DIY lash-ups, that are the problem (and the mice), which is often the case.
I have 3x bathroom extractor fans – the small ceiling mounted ones ducted outside – and, in keeping with many of the DIY add ons, they’re lashed up with flex. They come on when the light/s are switched on.
I can work out the zones etc – what’s allowed where and what isn’t, and gradually making sense of ‘IP’s’. I’m a little bamboozled as to what switching/protective method is required for these fans.
Do these fans need a fused spur, fusing down to 3A, or less? At the moment they are simply wired into the light circuit – presently protected by a 5 amp rewireable fuse (I know I need to address this, and the lack of RCD protection).
I’ve seen 3 pole (me no understand) fan isolators? What 3 poles are they talking about?
Any guidance on this would be appreciated.
Tony
Fans are normally wired from the lights so that it runs while the room is in use. The 3 poles are Pern Live, Switch Live and Neutral. The perm live is for fans with built in timer for over run. The isolators should always be fitted to a fan
You take a permanent live, switched live, neutral & earth from the light ceiling rose to the 3 pole isolator (perm live, switch live, neutral) and then onto the fan. The fan will start when the light comes on (using switched live) and then run on fit x mins after light goes out ( using perm live). Hope this makes it clearer.
about time they made a fan with a built in fuse holder! some fans state in the instructions that 5-6 amp light supply ok but most say fuse down.
i think a isolator may be only required if the room has no window, assuming repairs to fan are in the day time...
- - - Updated - - -
- - - Updated - - -
More and more manufacturers instructions are stating isolation required.
this is what you need, it only states to fuse the perm live , this is due to the fact that when the perm live is not present the electronics in the timer circuit have disabled the switched side from the circuit the three pole isolator is so that the fan can be isolated for maintainance and replacement MR seed 009.JPG
this is what you need, it only states to fuse the perm live , this is due to the fact that when the perm live is not present the electronics in the timer circuit have disabled the switched side from the circuit the three pole isolator is so that the fan can be isolated for maintainance and replacementView attachment 15478
Thanks everyone!
Finding my way around the forum - I notice this bathroom extractor fan issue is quite a 'can of worms'! No wonder I've been mystified - I don't feel so bad now!
This is an interesting fitting - I've never seen one in the flesh - any pointers as to where I can buy one? Or its exact name/manufacturer?
Thank you again
Tony
As pointed out above the 3 pole thing was to cover rooms with no windows and the resulting issue of maintenance with no lights....
Therefore....
Common sense tells me you don't need (oh! Contentious!) a 3 pole fan isolator for every fan!
Discuss
Isolators, Isolators everywhere :)
I prefer a local isolator for each fan (that way i get to turn it off when i dont want it to work ie loo breaks hehehe)
Seriously i do use a isolator for every fan i install regardless of light in rooms but i install humidi fans to bath rooms and only timer fans to wc,s with no windows (and as a norm i find most clients turn the isolators off anyway :( )
Another point I thought of - fitted one last week (in line monster fan) plugged in, in the loft. They didn't want it operated by the lights.
AIM - just re reading your post, I wan't suggesting NOT fitting a local isolator to a bathroom fan...? Just questioning the 3 pole necessity and highlighting the reason behind it. As in its not really nec. In a room flooded with daylight!
But manufacturer instruction overrules of course.
Had problems with a lighting circuit last week. Before fault finding had to link out four dimmers and remove SELV chandilier [2 feet across] and a couple of SELV lights in the kitchen. Took over an hour to prepare the circuit for testing. Then the same to rectify faults.
Could have saved over half an hour, and the help of a second person by leaving the SELV chandilier switched off and fudging the EICR.
I can't do that, I work for my self, so set my own standards. Some poor souls have pressure from above to get the job done.
Drive-by EICRs will cost lives. But unless challenged, nothing will change for the better.
Remember it will be the person filling in the EICR form who will end up at the Coroners inquest...
Reply to Bathroom extractor fans in the UK Electrical Forum area at ElectriciansForums.net
