S
SPARTYKUS
Good point Murdoch manu instrs rule.you do if the manufacturers instructions say you should fit them.
However my common sense tells me its not necessary most of the time
Well done. So in a fault situation the punter has no lights until the faulty fan is changed.
yes its the Click scholmore mini grid face plate fuse modual and the isolator only one i use now saves having loads of switches
unk:
