O
Ohwhen
How do I PAT test a breadmaker ?
It has a 3 core cable, and does not display a "Class 2" double square.
But there are no exposed metal parts for the Eath attachment.
Any screws seem to tap into plastic. and the cover is totally plastic.
Any suggestions ? Ohwhen
The internal mixing bowl area and paddle will be stainless steel connect your croc clip to one of these for your bonding and IR tests...
Thanks . However I now have 2 breadmakers on my bench and they both fail. One arrived boxed and appears unused. I have tried the metal "paddle wheel" and all things metal to get a contact. Next stop..... phone the maker. Thanks anyway.
look....use your loaf will you....
Thanks . However I now have 2 breadmakers on my bench and they both fail. One arrived boxed and appears unused. I have tried the metal "paddle wheel" and all things metal to get a contact. Next stop..... learn how to PA Test properly before going out and fluking it. Thanks anyway.
If no double insulated symbol then it has to have so sort of exposed conductive part.
internal bowl & paddle teflon coated , remove bowl & paddle and try test on side of casing or tip of shaft
Pat testing is not what it used to be whichever way you slice it.........
Thank you me old " flours". I rise to the warmth of your advice. I took a slice of your opinions, but.er, I first had to lay a few storks to rest. Yea st art with a contact right under the mixing bowl. I used a long long screwdriver. "Ho ! vis might be a good idea" I thought. I'll tell gran Nary ! He's getting crusty. I'll toast to him. Aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa ! Stop the world. Let me off.
Now then. My old Chinas . Any suggestions for a kettle with integral cable and no visible element ( under plastic mesh at bottom.)
Ohwhen,
Amp David,
