S
Shropshire
Working on behalf of the local authority and they wont bring in an overhead supply to the xmas lights on this big oak tree, so we have had to have and SWA dug into the ground from the cut out in the next field and we are really struugling how to fix the armoured to the tree without drilling or screwing into the tree, the gardeners twine is made of rubber and mettal so we cant tie it round the tree because this will restrict the trees abitility to expant, ANYONE ELSE HAD THIS PROBLEM. AND HOW DID YOU FIX YOUR TERMINAL BOXES AND CABLES TO THE TREE
just cleat it to the tree. a small screw hole won't kill it.
Permanant and the tree is consirvation so the couscel are dead carful with how they do things,
Could you not install a power post/pillar close by with ducting underground to the tree for the lights to be installed as and when? Becareful what fixings you use in oak as with some metals the oak happens to corrode it fast.
I was going to suggest simply strapping the SWA to the tree with ratchet straps. Then higher up you may be able to zip tie stuff to the branches.
Yeah i meant just digging it in the ground a bit and strapping the wood at the top up in the branches so it didn't look too unsightly
Catenery wire.
As you must have or will be excavating close to the trunk, fit a loose strap (webbing as used on ratchet straps?) around a root underground, then another on a branch above, wire between.
As close to the trunk as possible.
Definitely No nails (that's not NoNails, that's not any nails !)
Or steel conduit, painted, bent to the shape of the tree, cemented in at the bottom and strapped at the top, swa inside,.
Now , will the conduit need earthing/bonding?:13:
Sky hooks????
I think they may be asking too much of you not to put any fixings into the tree
