drypulse
Just spent a frustrating day fault finding and still left scratching my head, was wondering if anyone else had experienced something similar!
The kitchen we had been working in had been a proper DIY job (diagonal cable chases, no earth sleeving etc etc etc) so we were testing a ring circuit to ensure it was indeed a ring before adding new sockets to it, when we found that the neutral and cpc had continuity between them. (0.16 ohms, e-e was 0.76 ohms, l-l 0.46 ohms) We then proceeded to remove all the other sockets, take up floor boards and check all the junction boxes, visually fine, yet neutral and cpc were still connected. We traced this all the way back to the fuse board (old re-wireables) where it became more interesting...
By switching off the main switch, the neutral-earth fault would be cleared on the sockets. Turn it back on, and the fault would come back. We then checked the cooker circuit, same problem...
Now, the earthing for the fuse board is not via an earth cable back to the incoming mains, it is clamped to a metal box which houses the meter, fuse board and incoming tails. There is another clamp that connect from the box to the incoming earth cable, such as in a TNS system.
I thought perhaps the incoming neutral cable had broken when being pulled through steel conduit between the fuse board and the meter, resulting in an insulation resistance fault between neutral and earth that way. replaced the cable, fault still there.
Worse still, even when the main neutral and main earth had been disconnected, i could still get a continuity reading between the earthing clamp on the incoming earth and the neutral bar in the fuse board. The result was over 600 ohms however.
This leads me to believe that somehow the incoming neutral cable is touching the steel wrapping of the incoming cable, under the ground somewhere? It must have been like this for many a year, and no fuse had tripped and no signs of damage, nicked cables, screws hitting cables when fitting the board/meter etc.
No idea how to proceed from here? Really stumped I don't mind saying! Has anyone had a similar experience or has any suggestions (other then run and hide!) that I could try?
I will try and get a photo of it all tomorrow if need be, I hope I have been able to give as much information as I can, if you need any more I will try my best to help!
Any advice appreciated, Joe
on TN systems, the earth and neutral are connected together. look at your diagrams of TN-S and TNC-S.
So you’ve ripped up someone floor to find a fault that isn’t there? N>E are linked at the DNO transformer no matter what system it is. Isolate both L & N before testing.
I hope you haven’t got the gall to charge the customer for this!
Reactions: 3 people
I might not have been clear in my description, but everything was disconnected, if you take out the incoming earth, live and neutral you shouldnt get continuity between earth and neutral bars in the fuse board?
bonding??? when IR teating a circuit, you should remove it's neutral fro the neutral bar.
testing. must have teats on the brain.
Nothing worse than getting your teat caught in the neutral bar.........
don't know about that. getting it caught in the L busbar might be painful.
Shame on you all, why have you all got to be so rude? Yeah okay i could have tested it better, i only qualified in june and first time ive been trying to sort this myself.
Sorry i wasted your time with this and my time for signing up. Seems to me like you'd all rather be coks then be civil.
Oh dear, dear, dear. Another newbie with very thin skin.
Apologies mate but you did yourself rather wide open with this one, and as you can see that others think this too.
And don't be rude to the people that tried to help you, all be it in a rather direct way else you will get kicked off.
Every day is a learning day
Reactions: 2 people
Don't worry about it, you just overlooked it and thought it might be more than what it was. No biggy, I forgot what ohms law was once. Back when I was 4 so it was ok ;-). It's done now, at least you bothered to make the effort in finding out why it was belling out, take it easy
The op's first post was in the new members bit , he has just deleted it and typed rubbish instead .
It originally said how he was a farther and son team and how his dad had been doing it for more years than could be remembered , I bet his old man just found this thread and tore him a new one for disgracing the family company in such away !:omg_smile:
I wonder if they charged the poor sucker (who is now missing a kitchen floor) full rate for the lost day !?
Edit; Joe we all make daft mistakes mate , but it is the way we conduct our selfs after we realise the fact that make of the man !
Makes you wonder who taught him!
Reactions: 3 people
well with this thread and the recent RCD thread every day is a friday here at the moment and certainely entertaining.
clamp on gob. only to be released after brain is engaged.
Reactions: 2 people
Incoming cable - earth neutral continuity!
drypulse,
telectrix,
