R
ROADESPARKY
Anybody got a view on this. Emergency lighting key switch should it kill the power to all the lights so just the emergencies are on in emergency mode. Or should it just put the emergencies on in emergency mode and leave the normal lights on? I have always wired lights so that all lights go out bar emergencies but on this particular job I am being asked to do the other way.
both ways are acceptable. i prefer not to kill the normal lights when isolating the supply to the em's, due to the fact that it might go dark and compromise persons' safety.
But surely the emergency lights are surposed to give out a minimum of 1 lux so there must be enough light so people don't come to any harm. Isn't that the purpose of em lighting?
Agree with Tel, it would be unthinkable to kill power to all lights especially in big commercial properties. You wouldn't want to do em test out of hours!
+3 it should just kill power to the emergency lights and not effect the rest of the circuit.
fair enough, but think if you are testing while 100 staff are working. some of them might be in a test bay, working on live equipment. emergency lighting is designed to allow staff to safely move around/leave the building.
But surely the emergency lights are surposed to give out a minimum of 1 lux so there must be enough light so people don't come to any harm. Isn't that the purpose of em lighting?[/QUOTE
Not sure what your getting at, they work or they dont when in test!
Worzol99 nothing to do with work or not but do they give out enough light in an emergency to see. Been doing it my way for some 27 years( s**t that makes me......well old) Some very good points taken onboard. Glad they were mostly constructive and not damming.
horses for courses, bit like the difference between wiring a lighting circuit loop in method or junction box. just dependant on who wires it.
Good point ste77. Only asked the question because I got slated when I queared the method they asked me to do.
Nothing wrong with either, all down to preference & the situation being used in!
As mentioned killing the supply to the emgs only gives a better scope for the times when the test can be done, i.e doesn't need to be out of hours where as killing all the supply would be better suited out of hours but not essential! How you have done it is fine but to someone else it may not be, either way no rules or regs are broken!
Whilst emg lighting is being discussed, anyone got much experience filling in the emg lighting testing forms?
About to do my first for a small job done & some of the terminology is a little confusing ;-)
I may have messed up as have just done the emg lighting knowing from experience what is needed where etc but havnt done a proper design which now may bite my --- for commissioning ;-(
