J
jumpin jax
Is anyone finding it harder and harder to strip the inner sheath off in xlpe, especially being colder now?
some are a bit iffy. some just peel like bananas, way past where you've scored it.
I did actually heat it up with a heat gun today just to try and its still a nightmare:13:
I was hoping someone was going to come up with a magic trick like stand on your left leg whilst quoting the lords prayer backwards that it would just slide off
glanding 95mm 4c swa in a 35 deg C basement today.
the cables are heavier than i am.
you lot are ------- lol.
Some cable strips well, some is a nightmare! I seem to get more problems with bad glands. A lot of them seem to be made with less and less brass these days and I really struggle to get them screwed together.
Had some CW 32 glands the other day that were impossible to get on a 3c25. They were made by CMP. Found some others made by WISKA that went on perfectly first time!
I find the XLPE harder to strip than good old PVC, particularly when stripping many metres for weighing in :D (not enough to justify a powered stripper)
Had the same problem but different size gland. A CW20 just would not go on, scoured the van and found a loose one (Different make) that went on first time.
