Search the forum,
Discuss stripping inner sheath swa in the UK Electrical Forum area at ElectriciansForums.net
some are a bit iffy. some just peel like bananas, way past where you've scored it.
I did actually heat it up with a heat gun today just to try and its still a nightmare:13:
I was hoping someone was going to come up with a magic trick like stand on your left leg whilst quoting the lords prayer backwards that it would just slide off
Some cable strips well, some is a nightmare! I seem to get more problems with bad glands. A lot of them seem to be made with less and less brass these days and I really struggle to get them screwed together.
Had some CW 32 glands the other day that were impossible to get on a 3c25. They were made by CMP. Found some others made by WISKA that went on perfectly first time!
Reply to stripping inner sheath swa in the UK Electrical Forum area at ElectriciansForums.net
