J
jordi_ramis
Hi,
For months I'm looking for this piece without success:
A relay module powered by 220V and that can be controlled (toggled ON/OFF) by a wired NO (normally open) momentary switch (push button).
All I have found is some X10 micro modules that offer this functionallity but they very expensive as they are also X10. I'm looking for a simple way to ON/OFF a 220V appliance with a push button, the module has to be powered also by 220V I don't want to have to separate 12V (or similar) power supply.
Anyone know something like that?. Thanks a lot!.
A contactor can be made to latch on with a simple bit of wiring, granted you would also require a N/C stop switch in order to break the latch, cheers
I know is american but the theory is the same. One button for on and one for off.
I am obvoisly missing something here.
Can you please explain how that would work.
Having looked at the specs I am at a loss..................
A current is passed through a coil of wire. This attracts a piece of iron which moves a little lever with a hook on it.
The hook pulls on the teeth of a gear wheel one tooth at a time each time the coil gets current
This causes the relay to rotate the wheel in steps. This might then cause the wheel to turn electrical contacts on and off. - Google is your friend
Yes........ but the relay you referred to has not got that feature.... Google is indeed my friend LOL
