Discuss Anypne has found this piece? in the UK Electrical Forum area at ElectriciansForums.net
J
jordi_ramis
Hi,
For months I'm looking for this piece without success:
A relay module powered by 220V and that can be controlled (toggled ON/OFF) by a wired NO (normally open) momentary switch (push button).
All I have found is some X10 micro modules that offer this functionallity but they very expensive as they are also X10. I'm looking for a simple way to ON/OFF a 220V appliance with a push button, the module has to be powered also by 220V I don't want to have to separate 12V (or similar) power supply.
Anyone know something like that?. Thanks a lot!.
A contactor can be made to latch on with a simple bit of wiring, granted you would also require a N/C stop switch in order to break the latch, cheers
I know is american but the theory is the same. One button for on and one for off.
I am obvoisly missing something here.
Can you please explain how that would work.
Having looked at the specs I am at a loss..................
A current is passed through a coil of wire. This attracts a piece of iron which moves a little lever with a hook on it.
The hook pulls on the teeth of a gear wheel one tooth at a time each time the coil gets current
This causes the relay to rotate the wheel in steps. This might then cause the wheel to turn electrical contacts on and off. - Google is your friend
Yes........ but the relay you referred to has not got that feature.... Google is indeed my friend LOL
From the "Product Information" tab for RS 511-1026:
16A 2NO step DIN relay, 230Vac
16A Step Relays - 20 Series
The 20 Series are available as DPST-NO or SPST-NO + SPST-NC step relays. On
each successive energisation of the relay coil the contacts will change state
thus providing a step or "flip flop" sequence of operation. An override test
button allows manual advancement of the step sequence and individual mechanical
flags provide visual indication of contact status.,Typical applications would
include the control of lighting where push on push off or sequential operation
is required, automatic opening and closing of doors, gates, etc. Use in portable
or battery powered equipment requiring contact status to be maintained without
continuous supply to the coil and functions where manual override operation is
desirable.
17.5mm wide (EN 50022) 35mm Din rail mount
housing
Manual test button and mechanical indicators
Minimum impulse
duration: 0.1sec
Maximum impulse duration: 1 hour
Insulation between coil
and contacts (1.2/50μ); 4kV
Nominal lamp rating: incandescent (230Vac);
2000W
Compensated fluorescent (230Vac); 750W
Temperature range: -40 to
+40°C
Protection category: IP20
desirable.
housing
Minimum impulse
duration: 0.1sec
2000W
+40°C
Yep.. that will do....
Hi, just had a look at the specification, looks right to me
The 20 Series are available as DPST-NO or SPST-NO + SPST-NC step relays. On each successive energisation of the relay coil the contacts will change state thus providing a step or "flip flop" sequence of operation.
What you need is an 'Impulse relay' Din rail mounted. Controlled by a momentary push to make switch. Push once relay closes, push again and relay opens. Merlin Gerin do a good range.
Good luck
Jerry
Hi, thanks to all for your responses it seems that this effectively called 'impulse relay' or 'step relay' (these can have other functions) or 'latching relay' (sometimes is just called this way). It seems that the name varies from a company to another but I have found a bunch of products now I know what I'm looking for. Again thanks to all because I was looking for this for months withous success. Thanks, thanks!
Reply to Anypne has found this piece? in the UK Electrical Forum area at ElectriciansForums.net
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Hello! I'm needing some help. I'm wiring in a start panel, using a spst toggle, and a (momentary?) push button. The idea is to flip the switch to...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Im trying to make a Star Wars Prop for a course project where the dealine is comming up very fast in days and I need to do the report so really...
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
