and make sure it's fed in 2.5mm, not bell wire.
couldnt find the watts anywhere not even on screwfix website. the side of the box is 2.7kw for 230v or 3kw for 240v. The boiler is on same circuit so should i fit the 20amp? or should i run the boiler off the 6amp, and imm of a 16amp. will be calling the sparky back as he fitted the 6amp.
christ i give up!!!
These are the wattages in red
OK ..... it's a 16 amp MCB you need for this immersion heater and - as Tel says - 2.5mm T&E cable.
The 2.5 T&E goes from the 16 amp MCB in the consumer unit to a 20 amp switched flex outlet something like this: 20 Amp DP Switch with Flex Outlet and Neon next to the immersion heater & from there a bit of 2.5 3 core heat resisting flex to the immersion heater itself.
I'm not normally this helpful, but it's Christmas. :)
I thanks, will get teh sparky to fit a 16amp on his next visit. Everything else is as you state 2.5mm T&E and 20amp DP neon switch with 2.5, 3core heat flex.
Mate, I don't believe he exists.
I don't think it's about being perfect. A couple of questions to begin with:
Why are you asking on here what size MCB to buy for your electrician?
Why has your electrician fitted a 6A MCB for an immersion heater?
Why are you buying parts at all when you don't even know what a kW is?
Daz
Daz
Oh let me see on this erm I can get electrical parts at cost, or even free for that instance. 2nd I dont know why he fitted a 6amp. and i know exactly what a kW is where have i ever posted that!
Post 47 and then someone even highlighted them in red!
Quote from yourself earlier: "couldnt find the watts anywhere not even on screwfix website. the side of the box is 2.7kw for 230v or 3kw for 240v"
Need I say more?
Daz
