B
BillyH
What options do I have when I cannot put an emergency light above an exit because the ceiling is too low?
The ceiling is low throughout the office ( only about 50mm above architrave ) so seriously restricted to hang anything from it.
It's already been raised to what it is now
- - - Updated - - -
I would say no more than 100mm from the ceiling
I have suggested a answer, the drop down glasses on flush emergency lights are only 4" I would say, anyhow there you are, I'm sure you will work it out, roger and out.
Do you require lighted signs, is it an entertainment venue?
In premises that are not entertainment venues, a glow sign is usually sufficient.
Ask local fire brigade! I have found them very helpful when I needed advice on exit lights etc. If you can get them to email their answer. That way you and customer have record and the customer can add it to their building risk assessment.
