davel81
Hi
Ive got to run in some SWA cables for some large bits of equipment. Its TP&N, is there any issues with using 4 core and using the armour for the earth (ensuring the Zs is ok)?
There's a thread on here about this very subject and someone posted a table showing what was acceptable and what was not, so if you find it you'll know long before you do your Zs test.
as long as the armour is of sufficient csa. generally all SWA up to 90mm complies. some of the xlpe SWA doesn't.
Unless cost is massively different I'd always use 5 core.... here's a link for you to look at
http://www.gadsolutions.biz/component/k2/item/3-swa-as-cpc
Hi
more to the point , how "large" is large ? , in current rating.
Don't bother with that earthing nuts chart.
Do a search for 'john peckham' and use his chart.
As long as the armour meets the requirements then theres no problem at all...
Earthing Nuts - Speed up metal cable gland installation and EMI / RFI screening
Have a look through table 5 under technical info...
THROW THAT DAMMED TABLE AWAY!! It causes more confusion, than any help!!
Use this table where all the calculations have been done for you...
Blue = min CSA of cables SWA to comply.
(Red) = Cable does not comply.
Table for 70[SUP]0[/SUP]C Thermoplastic PVC SWA cables.
[TABLE="class: yiv1559363916MsoTableGrid"]
[TR]
[TD]
Conductor CSA​
[/TD]
[TD]
Minimum CSA of SWA to meet 54G​
[/TD]
[TD="width: 118"]
CSA of armour 2 core​
[/TD]
[TD="width: 118"]
CSA of armour 3 core​
[/TD]
[TD="width: 118"]
CSA of armour 4 core​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
1.5​
[/TD]
[TD="width: 118"]
3.4​
[/TD]
[TD="width: 118"]
15​
[/TD]
[TD="width: 118"]
16​
[/TD]
[TD="width: 118"]
17​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
2.5​
[/TD]
[TD="width: 118"]
5.7​
[/TD]
[TD="width: 118"]
17​
[/TD]
[TD="width: 118"]
19​
[/TD]
[TD="width: 118"]
20​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
4​
[/TD]
[TD="width: 118"]
9.0​
[/TD]
[TD="width: 118"]
21​
[/TD]
[TD="width: 118"]
23​
[/TD]
[TD="width: 118"]
35​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
6​
[/TD]
[TD="width: 118"]
13.6​
[/TD]
[TD="width: 118"]
24​
[/TD]
[TD="width: 118"]
36​
[/TD]
[TD="width: 118"]
40​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
10​
[/TD]
[TD="width: 118"]
22.6​
[/TD]
[TD="width: 118"]
41​
[/TD]
[TD="width: 118"]
44​
[/TD]
[TD="width: 118"]
49​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
16​
[/TD]
[TD="width: 118"]
36.1​
[/TD]
[TD="width: 118"]
46​
[/TD]
[TD="width: 118"]
50​
[/TD]
[TD="width: 118"]
72​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
25​
[/TD]
[TD="width: 118"]
36.1​
[/TD]
[TD="width: 118"]
60​
[/TD]
[TD="width: 118"]
66​
[/TD]
[TD="width: 118"]
76​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
35​
[/TD]
[TD="width: 118"]
36.1​
[/TD]
[TD="width: 118"]
66​
[/TD]
[TD="width: 118"]
74​
[/TD]
[TD="width: 118"]
84​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
50​
[/TD]
[TD="width: 118"]
56.4​
[/TD]
[TD="width: 118"]
74​
[/TD]
[TD="width: 118"]
84​
[/TD]
[TD="width: 118"]
122​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
70​
[/TD]
[TD="width: 118"]
79.0​
[/TD]
[TD="width: 118"]
84​
[/TD]
[TD="width: 118"]
119​
[/TD]
[TD="width: 118"]
138​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
95​
[/TD]
[TD="width: 118"]
107.2​
[/TD]
[TD="width: 118"]
122​
[/TD]
[TD="width: 118"]
138​
[/TD]
[TD="width: 118"]
160​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
120​
[/TD]
[TD="width: 118"]
135.3​
[/TD]
[TD="width: 118"]
(131) ​
[/TD]
[TD="width: 118"]
150​
[/TD]
[TD="width: 118"]
220​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
150​
[/TD]
[TD="width: 118"]
169.2​
[/TD]
[TD="width: 118"]
(144) ​
[/TD]
[TD="width: 118"]
211​
[/TD]
[TD="width: 118"]
240​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
185​
[/TD]
[TD="width: 118"]
208.6​
[/TD]
[TD="width: 118"]
(201) ​
[/TD]
[TD="width: 118"]
230​
[/TD]
[TD="width: 118"]
265​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
240​
[/TD]
[TD="width: 118"]
270.6​
[/TD]
[TD="width: 118"]
(225) ​
[/TD]
[TD="width: 118"]
(260)​
[/TD]
[TD="width: 118"]
299​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
300​
[/TD]
[TD="width: 118"]
338.3​
[/TD]
[TD="width: 118"]
(250) ​
[/TD]
[TD="width: 118"]
(289)​
[/TD]
[TD="width: 118"]
(333)​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
400​
[/TD]
[TD="width: 118"]
403.9​
[/TD]
[TD="width: 118"]
(279) ​
[/TD]
[TD="width: 118"]
(319)​
[/TD]
[TD="width: 118"]
467​
[/TD]
[/TR]
[/TABLE]
Table for 90[SUP]0[/SUP]C Thermosetting SWA cables operating at 70[SUP]0[/SUP]C.
[TR]
[TD]
Conductor CSA​
[/TD]
[TD]
[/TD]
[TD="width: 118"]
[/TD]
[TD="width: 118"]
[/TD]
[TD="width: 118"]
[/TD]
[/TR]
[TR]
[TD="width: 118"]
1.5​
[/TD]
[TD="width: 118"]
3.4​
[/TD]
[TD="width: 118"]
16​
[/TD]
[TD="width: 118"]
17​
[/TD]
[TD="width: 118"]
18​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
2.5​
[/TD]
[TD="width: 118"]
5.7​
[/TD]
[TD="width: 118"]
17​
[/TD]
[TD="width: 118"]
19​
[/TD]
[TD="width: 118"]
20​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
4​
[/TD]
[TD="width: 118"]
9.0​
[/TD]
[TD="width: 118"]
19​
[/TD]
[TD="width: 118"]
21​
[/TD]
[TD="width: 118"]
23​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
6​
[/TD]
[TD="width: 118"]
13.6​
[/TD]
[TD="width: 118"]
22​
[/TD]
[TD="width: 118"]
23​
[/TD]
[TD="width: 118"]
36​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
10​
[/TD]
[TD="width: 118"]
22.6​
[/TD]
[TD="width: 118"]
26​
[/TD]
[TD="width: 118"]
39​
[/TD]
[TD="width: 118"]
43​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
16​
[/TD]
[TD="width: 118"]
36.1​
[/TD]
[TD="width: 118"]
41​
[/TD]
[TD="width: 118"]
44​
[/TD]
[TD="width: 118"]
49​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
25​
[/TD]
[TD="width: 118"]
36.1​
[/TD]
[TD="width: 118"]
42​
[/TD]
[TD="width: 118"]
62​
[/TD]
[TD="width: 118"]
70​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
35​
[/TD]
[TD="width: 118"]
36.1​
[/TD]
[TD="width: 118"]
62​
[/TD]
[TD="width: 118"]
70​
[/TD]
[TD="width: 118"]
80​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
50​
[/TD]
[TD="width: 118"]
56.4​
[/TD]
[TD="width: 118"]
68​
[/TD]
[TD="width: 118"]
78​
[/TD]
[TD="width: 118"]
90​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
70​
[/TD]
[TD="width: 118"]
79.0​
[/TD]
[TD="width: 118"]
80​
[/TD]
[TD="width: 118"]
90​
[/TD]
[TD="width: 118"]
131​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
95​
[/TD]
[TD="width: 118"]
107.2​
[/TD]
[TD="width: 118"]
113​
[/TD]
[TD="width: 118"]
128​
[/TD]
[TD="width: 118"]
147​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
120​
[/TD]
[TD="width: 118"]
135.3​
[/TD]
[TD="width: 118"]
(125) ​
[/TD]
[TD="width: 118"]
141​
[/TD]
[TD="width: 118"]
206​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
150​
[/TD]
[TD="width: 118"]
169.2​
[/TD]
[TD="width: 118"]
(138)​
[/TD]
[TD="width: 118"]
201​
[/TD]
[TD="width: 118"]
230​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
185​
[/TD]
[TD="width: 118"]
208.6​
[/TD]
[TD="width: 118"]
(191) ​
[/TD]
[TD="width: 118"]
220​
[/TD]
[TD="width: 118"]
255​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
240​
[/TD]
[TD="width: 118"]
270.6​
[/TD]
[TD="width: 118"]
(215) ​
[/TD]
[TD="width: 118"]
(250)​
[/TD]
[TD="width: 118"]
289​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
300​
[/TD]
[TD="width: 118"]
338.3​
[/TD]
[TD="width: 118"]
(235) ​
[/TD]
[TD="width: 118"]
(269)​
[/TD]
[TD="width: 118"]
(319)​
[/TD]
[/TR]
[TR]
[TD="width: 118"]
400​
[/TD]
[TD="width: 118"]
451.0​
[/TD]
[TD="width: 118"]
(265) ​
[/TD]
[TD="width: 118"]
(304)​
[/TD]
[TD="width: 118"]
452​
[/TD]
[/TR]
[/TABLE]
Remember these tables refer to complying with CPC requirements, They do NOT refer to Bonding CSA requirements...
