Dean31
Hi Guys,
I'm making a bar and I have put 6 230v downlights in it, I have put the 1.5mm twin and earth into the load of the fused spur and the supply is wired into a plug that runs into the nearest socket. When I turn the power on I get power but the lights dont work?
Can someone explain why this isn't working?
Many thanks
Why did you not hard wire the supply to the fused spur? The plug top will be fused so it just seems like a bit of a daft way to do it.
Brightsparks answer is more than likely right but have you checked that your bar downlights are getting juice?
It's probably just a daft mistake that's easily corrected, just go back to first basics and check it all through.
you 've not wired then in series, i hope.
Have you put lamps into the fittings?
Have you used the correct transformer/drivers for the lamps?
Im gonna take a wild guess and say that the kafuffell valve is seized and therefore your lights don't work! Come onnn a bit more info please, its like me asking you, my cars not working, what do you think is wrong with it??
Have you got voltage at the fittings for a start???
i cant understand why it was not wired from a lighting circuit but now have to ask how far is the power getting ? fuse in the fused spur ?
am trying to give him a little credit that the bulbs are in but are they the correct fittings not 12V by mistake ? because so many none sparks asking things here i am not sure how much we take for granted any more
i were gunna say....whats goin on here?...
Thanks or the comments, the bar is being made for my wedding and being moved to the venue that why its not hard wired and not on a lighting circuit, the neutral had come loose in the spur so thanks brightspark, works fine and looks great now. Cheers
Another happy customer...
Thats 2 of you this year...3 up on last year...I'm doing well...
don,t forget to pm him his wedding invite,might be handy to have a sparks on standby lol.
