H
Hiddo
Look is not your business chancer or not I'm asking because half electricians I called to give me quate came with lots of bul...et you need that and you need that because law states this is how should be and at the end they want 1000 for two days work it's ripp off because I know basics
If you know it, just run it all yourself and connect it up and then you may just find out what the 1000ish quid was for. Have you priced up the cable?
I've just installed some 16mm SWA to my own garage and let me tell you, to do it properly it is not cheap.
quotes was from 2 16mm and one 25mm one suggested one day for diging trench witch took me 2 hours. Equipment to support sauna heater 9 kw water heater for shower now thinking 3kW would be enough 3 outside down light 35 wat .3 wall sockets and 6 led downlights inside. If the is any sparky close to Hersham surrey who can come and give me realistic quate always welcome thanks
