W
wolfiehogan
hi guys, i recently moved to oz to find work and have started a new job but wanted to ask you guys a question. the company i work for have to install a fuse in the meter cabinet so the installation can be isolated.which is fine. however some of these houses are 3 phase and the company i work for are putting in three seperate fuses for each phase. is this ok as the house is all single phase loads. as i taught you had to dis connect the 3 phases together at the same time eg a 3phase breaker. thanks lads
ideally, 3 fuses, which shoud be fitted by the supplier, then a 4 pole isolator. that will give you single point isolation for the 3 phases and N.
eh?....
god, if oz accepts folk that think like this......
lol....lol...
Actually that post Tony stuck up was not only hilarious but one of the funniest I have ever seen here, brilliant post IMO haha
