M
MDJ
Please pass me a gun
Can I just say a flat would normally get 1 JB And a house 2 ( one on each floor ) I.e downstairs usually wired to top of the stairs and upstairs wired to beside loft hatch. Just in case that wasn't clear....
I'm puzzled a bit about this thread.since when was wiring lights to a central joint box an abomination against sparking?
i was brought up on this method for rewires the advantages being a lot less cabling to pull down lath and plaster walls and easier termination of switches etc.
try getting 4 twins in a plaster depth box and you will see what I mean.
it was a far better method than looping everything at a ceiling rose in my book.
I would say if anything the loop in method was devised to save cable ,just a pest to connect really never liked it for that fact.Well for a start you shouldn't be pulling 4 T&E's into a plaster depth box in the first place!!
Why would you consider it better in a domestic house, than a tried and proven system. I doubt very much you would save that much cable if any, under a floorboard/floor sheeting situation.
1970-80s would be twin and earth using joint box
Kinda like conduit wiring minus the conduit! With the neutrals looped at the lights and the feeds looped at the switches?Around my way a lot of houses were wired using a completely seperate Neutral in single&earth , JBs all over the shop, no logical use of red and black singles. Very hard to fault find and trace where everything is. My own house has a big horrible JB on each floor with cables coming out all over the place. It's much easier to have all connections in the switches and light fittings in my opinion!
