M
MDJ
Ive seen lead cable systems with several Jbs linked under floors, but they were 1940s and 1950s systems, not 2013 lmao
as rare as a joint box in gloucester
did an eicr at two flats today both lighting circuits wired in the old double sheathed singles, not a cpc in sight.Around my way a lot of houses were wired using a completely seperate Neutral in single&earth , JBs all over the shop, no logical use of red and black singles. Very hard to fault find and trace where everything is. My own house has a big horrible JB on each floor with cables coming out all over the place. It's much easier to have all connections in the switches and light fittings in my opinion!
I would say if anything the loop in method was devised to save cable ,just a pest to connect really never liked it for that fact.
in my neck of the woods a 1930- 50 house would originally be done in steel conduit
1960s would be trs and early twin and earth using the joint box method
1970-80s would be twin and earth using joint box or loop in method
90s to present looped at switches
hardly a new fangled method
suppose it depends on the area you are in what methods are employed
nothing wrong with looping at switches if you have multiple lights, e.g. 12 downlighters. it's a bugger pulling them all out till you find the 1 where the switch wire is.
Please pardon my ignorance, but wouldn't you wire the d/l closest to the sw with the sw/wire?nothing wrong with looping at switches if you have multiple lights, e.g. 12 downlighters. it's a bugger pulling them all out till you find the 1 where the switch wire is.
The only system you got right there is the conduit in the 30/40's, as well as lead covered twin. From then on, be it TRS or PVC, it was always multi-core twin/T&E, and 9 times out of 10 using the 3 plate system. Nothing to do with saving cable, it's a logical wiring system.
The first house I bought in 1972 (built 72) had Red /Earth and Black sheathed and J/B.
The house I'm currently in, built 1988, has Red /Earth and Black / Earth and Loop in Ceiling Roses.
I think that's what i wrote earlier on, ...that those Octopus JB systems had their day in the 70's. I can't for the life of me see any advantage of these JB's in a standard house wire, you'd need 2 JB's then anyway!! . Best suited in my opinion anyway, to smaller bungalows or single storey buildings with a loft space and the like...
There seems to be a lot of confusion on this thread over multi terminal junction box Octopus type systems and plain Ashley 4 terminal traditional J/B.
Mine was traditional, not Octopus
