M
Minetsky
What will happen or the consequence of using the neutral of Y transformer IT system. I've read that neutral should not be used for IT system but dont know the reason behind. Cheers.
I've worked on a ship and we also use IT system and continues supply of power is a priority as what you've said engineer54.. but what does this sentence mean : ''Since the neutral is not solidly grounded, line-to-neutral loads cannot be served with this system''.
Cheers!
On the ship, neutral of geny is floating, distribution tx is delta-delta. 1 phase loads are somehow divided equally on each phase by the shipyard during ship building i guessed...
Maybe i have to let go of that 'sentence'... LOL. can't find the answer on the net...
What most forget, is that being a double fault earthing arrangement, it's a pig of a job finding the fault, on the occasion of a 1st fault which the insulation monitoring device will have sensed and be indicating by an alarm buzzer/bell...
