if it's just a couple of sockets, you can extend the existing ring, but you must fit RCD. if the kitchen is to have washer/dryer/dishwaher/kettle/micro/and god knows what other high power appliances modern woman can't possibly do without, then install a new circuit.
IPF
im new to this side of work as i have always been doin new build or full rewires, never working on existing intallations. im not wanting to do that just asking as the previous guy done that.
Fair enough. Do the job how you see fit, but make sure it is to done to current regulations, not on the say of someone who couldn't care less. I would have a word with your employer and make sure that he wants his work carrying out properly, without any corner cutting. It can be cut throat in the kitchen and bathroom world. Good luck.
Thanks mate, yeah definetly
You say your time served ...exactly what does this mean ..... i appreciate your out of your comfort zone and we are here to just remind you.... but with all due respect you should know any alteration or addition you do needs to comply and be done to the 17th so with all due respect if you are adding to an existing circuit your part must comply with regs thus be rcd protected in your case.
Time served to me means 3-4 yrs college interlinked with work experience hence im confused you asked such a basic question..... i dont mean the part about adding to ring but your not understanding it will require to meet 17th thus have rcd (their are exceptions from this rule but not applicable in this senerio)
I think you need to tell us, what the sockets are intended to be used for, and how they'll be wired.
I am aware of this hence the reason for opening this thread i was just wanting to confrim what i was thinking.
The person who im taking over from was doing it that way, and i wanted to get a second opinion before going into my new employers and saying how i am going to be doing it all different, and it hadnt been getting done right in the first place
The requirement to provide RCD protection for sockets, is only applicable to those intended for general use.
As such, if the sockets are intended for specific items of equipment such as washing machine, dishwasher, etc. there would be no requirement to provide RCD protection for the sockets.
There may well be a requirement to provide RCD protection for the cables, depending upon how they are to be installed etc.
Its a kitchen Spin in an house i dont think we should be even looking for exemptions to rcd coverage .... rcd all the time in domestic regardless and i would argue anyone trying to express exemptions, well i assume on of the sockets isnt for a kidney Dialysis machine then il back down ;) ....
Houses are the biggest place of electrical acidents, old people, children etc make it a risky environment and now we have the means to make it safer we should do whenever we can.
There not exemptions.
The requirement as I've probably mentioned on more than a few occasions, is for RCD protection to be provided for socket-outlets for use by ordinary persons and that are intended for general use.
If sockets are not for use by ordinary persons, or not intended for general use, there is no requirement for RCD protection.
pThe reason why we have this requirement for RCD protection for socket-outlets, is because they are used to connect mobile (as in hand held) equipment.
Such equipment is more prone to damage than static equipment, cords, cases and even the plugs and sockets can easily be damaged.
Just to add to this post and expand. Kitchen renewal was carried out with a new Fuseboard installed with RCD protection and ring within the kitchen. Provision of main protective bonding was also completed. However the supply to the flat was a 16/6 t&e cable with the earth confirmed using the adiabatic equation for suitability with a note on the EIC that 6mm2 earthing conductor was present. Is there any issue with this?
I take it that the T&E supply is part of the existing installation.
Did you point out in the note, that the earthing conductor is under sized, or just noted that it is 6mm²?
Matesrates,
Engineer54,
