B
Buzzed
ha ha
ha haYou sure it's not a microwave and the screwdriver isn't one of them leak detector things?
Ahh the Neon screwdriver - the most reliable piece of kit one can need.
I'm beginning to think all these threads that are started are completley made up to get a reaction. I mean the OP contradicts himself....he can spell properly which suggest not an idiot, but then he uses a neon! doh!
OP get a spark's in and sort it out properly with the correct test procedure's. (We have super-duper neon drivers which are a slightly better to test with.)
:welcome: to the forum though buddy! all the best for 2013 and don't be touching anything else you presume is live![]()
All I know is how V=IR works!!!
With the OP being in Sri Lanka, I wouldn't recommend a local forum member. God knows what standards they have.
partly because these mickey mouse neon testers are fit only for scratching your arse (or --- in america). bin it and get the installation properly tested.
My favourite part is - "However there's no electric shock when I touch it by hand"
We all know there is no better way, when a tester of some sort (albeit a load of junk neon driver) shows a voltage, to double check it by touching it. But remember all you overly curious, soon to be dead electricity adventurers, if you insist of stroking a live voltage, always use the back of your hand so you dont grip the conductive surface, alternatively use your tongue to throw a little moisture in the mix for a truly fantastic result...
P.s, this is post is NOT genuine advice, disclaimer notice attached.
I was careful about it !!!I was careful about it !!!
Thanks for taking time to respond.
