J
jimmylaud
hi just checking never done bt points before just checking this is right basically a radial ciruit using connections 2,3,5 ? any help would be much appreciated
From the master point,2,3,5 as you said.Blue/white-2.White/blue-5.Orange/white-3 is the ringer if the extensions don't have capacitors in.
Just to add a note, you should only have a master at the start, if your REN gets too high then you may stop it ringing all together
I worked out of the Swindon,Andover,Oxford,Thames Valley and Guildford offices.Haven't worked for them now for 2 years.I take it you used to work for them.
I worked for Birmingham Cable which later became Telewest, and then I left just as Virgin took over
jimmylaud,
thepurple1,
