Ah, thats interesting, people always slate TT'ing garages but never explain why. And i didint realise you need permission to export the suppliers earth . . . .you learn somthing new every day!
I always carry a few rods so i can stick one in, belt and braces i suppose.
And is there any reason you shouldnt connect the earthing arrangements both ends? (I usually only connect one end i just noticed a lot of people on garage posts saying do both)
Thanks for the advice
Yes because you don't want an earth fault within the garage installation affecting the consumer rcd, keep the earthing separate, gland it consumer end and earth the armouring that end, In my opinion , good luck with assessor.
By rights you should really install a rod for the garage, you shouldn't really export the suppliers earth out of the equipotential zone without there written permission, people will moan regarding this but that's the deal. That could be one of the things your assessor looks for because I remember a few years ago during an assessment I was asked this exact question. And you shouldn't connect the two earthing arrangements together via the armourings.
What complete and uttet tosh. Find me a rule or regulation that says exporting a equipotential zone is not allowed.
Soo many rumours regarding exporting suppliers earths it's ridiculous !!
Your 'extending' not exporting your equipotential zone so nothing wrong with that.
Why would you opt for a crappy TT when you have a much lower earthing system already !
Hmmmmm thanks for the input chaps . . . . .
So in your opinion, would what I plan to do in my OP be adequite?
Im probably going to start another debate but im just trying to get this job as near to 100% right as i can, after all, how can those of us with fewer years under our belts learn if we are too scared to ask the learned ones among us.
Ohhhhhh its snowing again
Aw shucks . . . . . and i only wanted some friendly advice
Maybe we should change the forum name to 'fight club'
Well done Dill - I was just going to say that's a load of Bo11ocks, but you were slightly more polite. I think Mr Onions needs a little more time back in the soil.
And to the OP - By the sounds of it I think you'll be just fine, carry on.
use the 3rd core of the SWA as cpc and the armour as a bonding conductor. or is it vice versa. i can never remember.
Again dillb spouting off about shat you don't know, you get permission off the supplier and I will apologise. You go rough it in.
