Ooops ya will be on about my black markings on e live cores haha? Apart from that, what's your opinions on my board? :/
Doesn't look too bad with what you had to work with, I prefer to leave a little more length on the cables, I prefer the tails from the bottom looped into main switch so it is impossible for them to be pulled out no matter how much downward force you put on them .
- - - Updated - - -
And yes I meant the black marks
Neat enough. Maybe leave a bit more free length where possible (I know it sometimes isn't). How did you achieve the specified IP rating where you brought your tails in at the top? My preference is to avoid bringing cables in through the top surface or, if necessary, add a piece of trunking above to preclude finger access to the top surface of the CU enclosure.
I'll have to remember about the black stripes if I want to mark up cores for when my sheath markings are out of sight. Quite a neat idea. I notice that you changed your mind over the positioning of CBs 2 and 3.
Edit: Just noticed what lookes like a big rectangular hole in the bottom face. How did you cover this to stop finger access?
Edit 2: There don't appear to be enough CPC terminations for the number of final circuits?
A small fire alarm panel changeover we completed a couple of years back.
The room where the panel is located is not waterproof by any means. Usually when it rains outside, it rains inside too. (including above the panel)
Needless to say, the site will not weatherproof the building as they plan to pull it down in a few years, but they have to have a fire alarm system as it covers more than just this area.
Before:
Panels designed and built in the office prior to taking to site:
Last stages of install and commissioning: (prior to the arrival or replacement interface units and a glass windowed door for the right hand side box)
Nice Mx setup, and good solution to the water problem, out of interest, are the din loop controllers switching plant, as there is a lot of them. Or are they being using as zone monitors into an existing old conventional system.
The box on the left has a mixture of Din rail I/O's and Zone Monitors.
The zone monitors are used to pick up all of the old non addressable zones.
The I/O's are used to signal a fire condition for each zone and general fault back to the security control room via an old network alarm module located nearby.
In the box on the right above the MX panel is an advanced sounder booster card with 2x 4 way sounder circuit controllers.
