C
cunnishaun
Hi all,
First of all as i am new here let me introduce myself, I'm Shaun, a time served Electrical Maintenance Engineer working in Lancashire. I have completed a 4 year modern apprenticeship in electrical/electronic engineering, have completed HNC in electrical engineering, and have also completed a nvq level 3 in electrical engineering. Plus I've completed the 17th edition.
The reason I tell u all this is I want to know, with help from my list of qualifications above, legally what work am I able to do on my own house? As i am have an engineering background i am unsure on the laws. Could I do a rewire and get it signed off by somebody else? Could I make alterations? Or nothing at all? If the latter what courses do I need to complete?
Please no 'plastic spark' comments!! Haha :)
Thanks for any info
Cheers Shaun
Purely maintenance or are there other strings to you’re bow? Most in industry will do installation work as well, if so you have you should be well able to run rings around domestic work. The only fly in the ointment is as you rightly say is the nonsensical legal aspect. This mainly depends on what you are planning to do.
Do tell.
Ye I do installation work too, I am capable of running rings and other wiring BUT can I do it legally? I was planning on doing a full house wire, new cu, all new circuits using new cable and new faceplates and fittings. What be the legal limit I could do?
Cheers
All domestic electrical work is now covered by the Buildings Regulations (Part P).
Some work such as replacing a CU, installing new circuits, any work in a special location (other than replacement of existing equipment) is notifiable.
At the moment special locations are within the zones of a location containing a bath, shower, sauna or swimming pool, a kitchen, or work outside other than to install fixed equipment to the side of a house such as a light, air conditioning unit or radon fan.
Any other work is not notifiable.
The special locations are due to change in April, being limited to just the zones in a location containing a bath, shower, saune or swimming pool.
There's to be no change for replacement CUs and new circuits, they will still be notifiable.
At present, a householder can pre-notify the work, to building control as with any other building work that falls under the remit of Building Control.
Another option is to engage a tradesman you is a member of a 'competent persons scheme', often referred to as a 'self certification scheme'.
There is a process where work can be reguarlised after completion, but it is a lot of hassel and quite expensive.
In April, there is supposed to be the option for registered 3rd party inspection and notification, but as yet details of any such scheme have not been decided.
Legally, you can do whatever elctrical work you want.
The illegal bit is if you don't notify such work as requires notification.
just echo what spin has said. spot on. just like to add that if you do the work, test and certify the installation, yourself, not bother to notify, the chance of being prosecuted if nothing goes wrong, is about 1 in a million. where you could come unstuck is if you were to put the house up for sale, the prospective buyers might request documentation that the work has been notified.
I totally agree with all the info above and should you need the documentation if/when you sell your house, I useually find an EICR (PIR), if carried out properly, will normally satisfy most people.
Just to add, I did this for a guy who had just built a house to sell. He did everything. The LABC wanted to see some certs for the electrical work, when he called me, I told him I could only do an EICR, so he contacted the LABC and they said that would be ok.
Jay
Jay
A sensible LABC at last!! lol!! Just goes to show how circumventable the Part Pee system really is!! lol!!
This would be my experience too,with issues at time of sale. Whether it's a certificate concerning electrical installation or any other planning matter (unless of a gross nature) completing the sale usually requires no more than phone calls and expense. Remember,the sale process includes at some stage a completion date usually given at a time when all the neccessary documents are not to hand. This means all concerned then work towards that date,NOT any other "legal" requirements. Over the years i have seen many sales,and been involved in many,where you would have been sure dodgy work,boundary disputes and non-notified additions would have stopped or delayed completion,but all it took was money and myther. In relation to the OP's original question,if the work was done to standard then the chances of future problems are minimal,not that i would condone such action.......In point of fact there are lots of types of industries where the legal framework only comes into play when pear-shaped,for instance,say i have been doing dentistry work on my own families teeth. There are no issues ,problems or complaints and i promise to take them NHS in the future. When do you think i will be arrested? By the way,welcome to the OP and don't let em'grind you down...
Hey guys, thanks for the warm welcome and the replies.
Looks like I better make a start then! Get it done ASAP! I'll be busy this weekend! I'm not looking to sell for a while so no need to worry about certs for now then!
Thanks again
