T
Thomps
Just been to do a job at a house and when I came to do the test certificates I couldn't find any sign of a 10mm water bond, there was a 10mm gas bond however.
Now the property is only just 12 months old and on a new estate of 80 houses. I asked the occupier for the certificates when the house was bought, he handed them to me and there is no indication of it on there either. I checked the condition and there are signs of copper after the meter with a 1/2 turn isolation valve.
Am I missing something here or should it be installed? I have warned the occupier about it and he is fine with it at the moment but has no problems with me going back to install some bonding.
So are you saying it's wrong then?
Only you can make that judgement because only you can see the installation.
What Sintra is saying, is that the time to ask these questions is before undertaking any work not afterwards.
Why not do the proper thing and check bonding etc before carrying out your works.
Look stop suggesting these obvious things, I may keep agreeing with you and it looks bad to the rest of the guys here--------------MDJ is a creep --- around the Mods LMAO
I know its wrong, I was asking why it would of been missed or any reasons that I don't know of for it being missed. I would of popped a 10mm earth in if I had it with me. I assumed with the install being less than 12 months old it would of been in tip top condition, (I know for future).
It's wrong because when YOU carry out any installation work all bonding and main earthing must be in place before commissioning your work.
