P
Plonker 3
It is supplied via a plastic pipe. Does this mean bonding is or isn't required?
Test it to see if it is a extraneous conductive part.
Maintenace and installation work are two different things altogether. All installation work requires bonding in place maintenance doesn't.
Please tell me you have a copy of the BGB
How does a RCD stop a extraneous conductive part coming live?
Big green book, BS 7671 latest edition.
IR Test between that copper that you said was there and the met and if its more than 22 kohms don't bond it and if its less it needs bondingIt is supplied via a plastic pipe. Does this mean bonding is or isn't required?
like fishing in the rain![]()
part p non applicable in scotland
Better ask the guys at screwfix ......... Can someone post something interesting please :28:what do you think?????????????????????????????????????????????????????????????????????? FFS
I will quite happily feed the trolls today as I am stuck in a hotel room in Manchester bored out my mind.
- - - Updated - - -
Since when was part P the same as the regs?
you really must try harder.
do some research guy with weird hat
Research on what? We are discussing bonding not Part P, you were the first to mention Part P maybe you could explain you reason why.
