W
Welchyboy
In a nutshell they are all as useless as each other, absolutely drive me crazy, smallest excuse and they make up some excuse not to do their job
only British gas electricians are worse
loofks like you are missing the paxolene cover on the top of the board, probably kicking around at the bottom of the intake cupboard somwhere
- - - Updated - - -
^^^ha you beat me to it!
D'you know, I'm sick of people having a pop at BG electricians.
I've worked for em for 5 years now, not the place I'd ideally be right now but hey, I've got mouths to feed and bills to pay.
All the lads I work with have plenty of experience and are generally a good bunch.
Maybe a few bad uns slip thru the net but to tar us all with the same brush.....ffs.
Maybe it's just my area then, or your the exception, as time after time I turn up to jobs where after 3 or 4 call outs by different engineers, the customer has given up with them or they sticking their danger stickers over everything then scaring the life out of people and issuing a massive quote to remedy work which only turns out to be a simple fault,
Last one was a fault on a ring main, the engineer failed to find fault after 3 visits, then blamed the problem on green goo and said the whole circuit was dangerous and had to be rewired and refused to re-energise the circuit
In about 15 minutes i found a crushed neutral in the back of the third socket box i looked in, after a further inspection green goo was present but VERY scarce
£50 + vat call out, peeled off his silly sticker on the consumer unit and left
It's all good though more customers for me
