T
thekingiam
been working on some comunal flats above a take away other electrician has walked off site.
the owner wanted to rent one of them out today so asked me to turn on main cut out fuse at meter he told me it had been powered up before and know problems, stupidly i did! checked flat and cu and still no power. so turned off at meter and explained i need to test.
5 mins later the boss was in takeaway and says half the lights in shop had just gone out, checked at distribution board in take away with voltage tester and no voltage from one of the 3 phases to the neutral bar.
so guess i have blown one of the three phase main cut out fuses and need to ring supplier to replace.
will they charge for this?
The job will take aslong as YOU think it needs to take, not anyone else.
